Question from a beginner-
Preface I am a "sub novice" and have no electronics experience or training.
I am building a halloween costume for my son as a Robot and have set up some basic LEDs. I found a beginner's tutorial on instructables.com which was very helpful in explaining things from the ground up.
While at radio shack I found the blinking LEDs, which of course I thought would look cool. From what I have read online so far, I sense that setting up the flashing LEDs is beyond my knowledge base (or time frame!) right now, so I am going to only use regular LEDs for the costume. However, I find this stuff very interesting so maybe you can shed some light for me.
My questions:
-The led has three leads instead of two. What is the third for?
- I hooked one up with the appropriate calculated resistor. It blinked for about a minute or less and then stopped. What is the reason it stops?
-My web research talks about using a timer circuit ("555"), which I wiki'd but obviously alot of the technical description is beyond me. Is a timer part of using these flashing LEDs?
Thanks alot to anyone willing to explain these fundamentals.
My questions:
