- Joined
- Jan 21, 2010
- Messages
- 25,510
the 2 bias resistors are equal, so the trip point will be when the thermistor resistance matches the current setting of the potentiometer.
Since it's a 15k thermistor, the resistance will vary around this point. I would expect that with a 100k pot, you're using only about 10% of its travel making it quite hard to adjust.
I would measure the resistance of the thermistor when at the temperature you wish to trip at (or pretty close to it).
If that turns out to be 10k, then replace the pot with a 4k7 resistor and a 10k pot. This will give you easier adjustment around the point that you want it to trigger.
Note that because this is a Schmitt trigger, if the temperature rises to the point to trigger the relay, it will need to fall substantially to turn it off again. Increasing the 270k resistor will reduce this effect (and you've already been advised to increase this to 1M).
Because this is a very simple circuit, it is difficult to set the spread of temperatures exactly, nor to make it consistent across all temperatures you might set it to. You could experiment with different values to get the spread you require. Again, measuring the temperature of the thermistor at the points you wish it to turn on and off may help us in suggesting a value that will give an approximate temperature range)
Using a 10 turn (or more) pot will also be effective in making the adjustment easier, however making sure the pot has the appropriate value and placing a sensible series resistor in place would still be advisable.
If you can find the datasheet on this thermistor, and tell us what temperature you want as the trip point (or what range of temperatures you want it adjustable over) then we can suggest something for you.
