Bar-graph display ?
Discussion in 'Electronic Basics' started by Guest, Jul 27, 2003.
  1. Guest
    Guest Guest
    There is a circuit for a bar-graph display,
    http://www.aaroncake.net/circuits/vumeter.htm
    The circuit has a diode between the input an pin 5
    amd is described to have an input range of 0 to 1
    Volts.
    My question is wouldn't the input range have to
    start at 0.6 Volts due to the diode ?
  2. cpemma
    cpemma Guest
    Yes, but the diode isn't needed, the 3915 can handle the negative-going part
    of the wave without false output.
