bandgap voltages
Discussion in 'Electronic Design' started by John Larkin, Mar 4, 2008.
  1. John Larkin
    John Larkin Guest
    Why are all the bandgap pseudo-zeners 1.25 volts or more? Is there
    something in the physics that prevents them from being any lower?
    John
  2. linnix
    linnix Guest
    The AVR internal bandgap is 1.1V. So it should be possible with a
    discrete.
  3. Possibly the band gap of silicon (1.12eV)?
    A Ge one should be possible at around 0.7V.
    The reference in the LM10 is about 200mV but it requires a higher
    voltage to power it (about 1.1V).
    http://www.national.com/rap/Application/0,1570,24,00.html
    Best regards,
    Spehro Pefhany
  4. Jim Thompson
    Jim Thompson Guest
    A (standard) straight vbe + NkT/q stack always gives around 1.25V ±
    However, if you have a low-VDD/low-current requirement (as I often
    do), you can make them anything you want by doing current mirror
    tricks.
    But there's still the limitation that it takes around 1.4V VDD to run
    it.
    ...Jim Thompson
  5. Phil Hobbs
    Phil Hobbs Guest
    That's where the Vbe drift cancels out the PTAT drift. It varies a bit
    with the current density in the Vbe.
    Cheers,
    Phil Hobbs
  6. Robert Baer
    Robert Baer Guest
    As i understand it, yes; it is the "definition" (actually an
    un-achieveable limit point) that "sets" that value.
    Mr Pease has an elegant explaination.
  7. John Larkin
    John Larkin Guest
    One of my guys just pointed this out to me:
    http://www.analog.com/en/prod/0,,769_838_ADR510,00.html
    I wonder how they do it.
    John
  8. Interesting. The usual parabolic tempco curve for a bandgap is
    inverted. Looks like it would overcorrect a bit if you put it in
    series with the output of a TL431 to get 1.5V.
    Best regards,
    Spehro Pefhany
  9. Fred Bloggs
    Fred Bloggs Guest
  10. John Larkin
    John Larkin Guest
    That appears to describe 3-terminal refs that need about 1.2 volts to
    power them. The ADI thing is a 2-terminal, 1-volt shunt reg.
    CMOS? SiGe? Some new trick?
    They may have a patent, too.
    John
  11. MooseFET
    MooseFET Guest
    The noise number makes it look like a bandgap reference based design.
    1V is enough that an op-amp of sorts can be used. I remember reading
    a paper on a topology that leads to "op-amps" down to 0.8V The op-amp
    was really a Norton amplifier with resistors built in.
  12. Jim Thompson
    Jim Thompson Guest
    Perhaps, but I doubt that Analog Devices has that particular
    configuration.
    Note the 100uA _minimum_ current... there's a lot of circuitry in
    there.
    "Shunt" allows the lower voltage operation.
    ...Jim Thompson
  13. James Arthur
    James Arthur Guest
    I'm surprised no one's mentioned the LM10 -- 200mV:
    http://www.national.com/ds.cgi/LM/LM10.pdf
    One of the Bobs wrote it up somewhere, I think.
    Cheers,
    James Arthur
  14. Fred Bartoli
    Fred Bartoli Guest
    James Arthur a écrit :
    I think Spehro did.
