Below are a couple of references on the proposed ban on incandescent
bulbs.
But first find an artcle on the good the bad and the dangers of CFLs. I am
a happy user of CFLs, but I will
make a few changes with info from this article.
( I have improper fixtures and dimmers)
http://sound.westhost.com/articles/incandescent.htm
Early in the article I see the big "alarm bells" being enclosed fixtures
and dimmers.
My experience in the USA, which has a ban mainly on "regular shape and
size" ("A19") 75 and 10 watt incandescents scheduled to take effect in
2012, and to extend to affect 60 and 40 watt ones in 2014.
I am seeing dimmable CFLs beginning to make an uptick in presence and
availability. GE makes them, and I see them at Target. Sadly, they cost
more than non-dimmable ones - but still less than nondimmable ones cost
about 10 years ago (inflation-adjusted) or 15 years ago (not
inflation-adjusted).
There are ones that can take the heat of enclosed fixtures and even the
heat-hellhole recessed ceiling fixtures. I have in mind ones that have
been around since late 1999 - Philips SLS non-dimmable models of 15, 20
and 23 watts. I suspect that others are already available, and that the
upcoming incandescent ban will create a market for more of them still.
Incandescents having no major modifications in the past 125 years? How
about filaments being carbon 125 years ago and tungsten now? How about
inert gas fill to slow filament evaporation to allow higher filament
temperature?
(Only increases efficiency for a given wattage/voltage/life-expectancy
when *roughly* wattage is around or over 1 watt per millimeter of overall
filament length (before uncoiling), meaning current around .2 amp,
somewhat less with premium fill gases [krypton or xenon]).
How about halogen lamps? The small bulb/"capsule" size and tougher
bulb/capsule material permit higher fill gas pressure to slow filament
evaporation more, and reduce the cost of premium fill gases. Would you
believe this makes more difference than the halogen does - the halogen is
not that good at returning evaporated tungsten to whetre the filament
suffered evaporation the most - what it does more is keep the inner
surface of the bulb clean!
How about "HIR" - halogen lamps with a coating to reflect infrared back
to the filament! That in practice increases efficiency about 35-40%
compared to halogens without this technology. I see use of this
infrared-retroreflection technology being expanded because as far as I
heard the USA's upcoming "incandescent ban" does not ban technologies but
requires efficiency standards that HIR can meet.
This is still an incandescent technology! Then again, the cited article
talks about California, with some really loony leftwingers from LA county
and some really loony rightwingers from Orange County, and brain-scrambled
voters in these counties willing to elect nutcases to office. The
"statehouse" in Sacramento should be "known to the State of California" to
cause cancer, brain damage, birth defects and reproductive harm, and power
shortages and excessive taxes and individual freedom being lower than in
the other 49 US states!
"Meanwhile, they remain incredibly inefficient, converting only about 5%
of the energy they receive into light."
Probably close to true on average - if by "light" one means
electromagnetic radiation of wavelengths 400-700 nm, the most common
definition of "visible light".
The "USA-usual" 100 watt 120V "A19" with doubly coiled filament and
design life expectancy of 750 hours achieves about 6.7% efficiency in this
area. Most other incandescents achieve a little to somewhat less.
Sadly, the competition that produces better numbers still generates ones
small enough to disappoint many:
Fluorescents: CFLs are in this area about 16-20% efficient. 4-foot T8
lamps powered by high frequency electronic ballasts are about or hardly
over 30% efficient.
Gain in overall luminous efficacy is greater than the gain in conversion
efficiency because the spectrum of these fluorescents is concentrated to
wavelengths more favorable for higher luminous efficacy. For example,
most fluorescents (and many other artificial white light sources) have a
"shortage" of deep red wavelengths, which the human eye has lower
sensitivity to.
LEDs: None on the market now significantly outperform 4-foot T8
fluorescents powered by high frequency electronic ballasts, either in
efficiency or overall luminous efficacy. (Exception - slight
outperformance when significantly underpowered.) The most efficient
latest laboratory prototype white ones that I heard of achieve 150
lumens/watt. Extrapolation from the most recent datapoint that I have on
both overall luminous efficacy and conversion efficiency of one of these
(27.7% efficiency, 91.7 lumens per watt) leads me to think the best
efficiency so far in announced laboratory prototype white LEDs is
somewhare around 45%.
I am sure they are working on advancing this!
Low pressure sodium: Best I heard so far for a commercial product is
180 lumens/watt, and for 589 nm that is about 34% efficient. 1 watt of
this wavelength is about 525 lumens. I suspect that high frequency
electronic ballasts can improve LPS efficiency somewhat - maybe to about
38-40%, or about 200-210 lumens/watt.
- Don Klipstein (
[email protected])
