BALUN transformer for capacitive loads
Discussion in 'Electronic Basics' started by [email protected], Aug 22, 2006.
  1. Guest
    I need to drive 2 capacitive electrodes with out of phase RF (0-100
    Vp-p, 10KHz - 1MHz). For this purpose i got myself one of the T&C power
    amplifiers (AG1021) with a gain of 53dB upto 1MHz. I planned to use a
    BALUN transformer from North hills (75 ohm: 75 ohm, 1KHz - 2MHz) to
    unbalance the amplifier RF. I use a function generator as a source.
    However, things are not working as i thought.
    The setup is as follows: Function generator feeding the signal to the
    power amplifier. The output i measure on a oscope is good 100 Vp-p for
    small input signal < 1 m volt (10Khz) . As soon as i connect the output
    of the amplifier to the BALUN, my reflected power to the amplifier
    shoots up. And the 2 unbalanced outputs of the BALUN show merely 12
    Vp-p.
    I know the power amplifier is rated for 50 ohm, is there an impedance
    problem. With the capacitive load at the secondary of the BALUN, the
    impedance which the amplifier at the primary is surely not 50 ohms.
    How can i overcome this, can i just use a BALUN with more turns on the
    secondary? Say 50 ohm : 600 Ohms BALUN to step up the voltage.
    I would appreciate the suggestions.
  2. Guest
    can you rephrase that?
  3. That's right. with a capacitive load, the load impedance falls as
    frequency rises. Using a transformer to change an unbalanced source
    to a balanced pair of outputs does nothing to solve this mismatch.
    The largest capacitance the unbalanced 50 ohm load can drive to
    nominal output voltage at 1 MHz is about 3000 pF. If the balun steps
    the total voltage up 2:1 then the capacitance each side can drive is
    half of that.
    So what capacitive load are you trying to drive to 100 v p-p at up to
    1 MHz?
  4. Guest
    In brief, i have 2 electrodes each with ~20pF capacitance to ground. I
    need to drive each of them with an out of phase RF signal i.e. one with
    A cos wt and other with A cos(wt-180). The RF amplitude and frequency
    range is around 0-100Vp-p and 1KHz to 1MHz.
  5. So if you need to apply positive 100 volts to one electrode, while
    applying -100 volts to the other electrode, and each electrode has 20
    pF to common (10 pF in series) the impedance across the differential
    output is about 16 k at 1 MHz. Neglecting stray transformer and
    wiring capacitance, you should be able to use a transformer with an
    impedance ratio of up to about 318:1. Of course, those stray
    capacitances may not be at all negligible, compared to 10 pF, so the
    real limit is probably about half that or less. 100:1 may be
    achievable. I think I would try a toroidal core transformer, with a
    center tapped secondary having 10 times as many turns as the primary.
    At this frequency range, I doubt that worrying about transmission
    line transformers is worth the trouble. This is more in line with
    switching power supply components. The core size will be dominated by
    the low frequency extreme (the primary will have to have an inductance
    of at least 8 mHy to stay above 50 ohms at 1 kHz), and winding
    capacitance and leakage inductance will dominate the high frequency
    problems. With a 100:1 impedance ratio, the implied minimum secondary
    inductance is .8 Hy. Winding a tightly coupled .8 Hy inductor with
    low losses at 1 MHz and low capacitance is a fair trick.
  6. Guest
    John,
    Thank you, this all makes sense to me. I have started to find the right
    torroid for this. I haven't made any transformers before in house,
    wondering if there are any practical guidelines.
    Do i have to worry about the saturation of the core, keeping in mind
    that i have 100 Vp-p at the secondary?
  7. At the low frequency end, saturation is the prime consideration. This
    is because the integral of voltage over time (for each half cycle) is
    proportional to the flux swing of the core. So if it will handle 1
    kHz at 100 volts, it will not saturate at any higher frequency.
    Here are some tutorials on transformer design:
    http://www-s.ti.com/sc/techlit/slup123.pdf
    http://www-s.ti.com/sc/techlit/slup126.pdf
    http://www.ee.surrey.ac.uk/Workshop/advice/coils/index.html
    http://www.mag-inc.com/library.asp
    http://www.triodeguy.com/transformer_math.htm
  8. Guest
    John,
    So, i got myself a ferrite Core torroid with permeability 5000 and OD =
    ..87in and ID = .25 inch.
    I wound up couple of turns and connected it to the output of the 50 ohm
    wavetek. The output dropped from 1 volt to few mVs at 10 KHz.
    So i kept on increasing the number of turns untill i get half a volt
    which is 12 turns now, this implies 50 ohm impedance at 10 KHz.
    Calculating it back, tell me the inductance is arpprox. .8mH. Now, to
    get higher impedance at 1KHz i have to wind more turns on the primary
    say 20 turns. That will imply around 200 turns for secondary, which i
    am not sure i can fit on this small core. I use a 30 Gauge magnet wire
    which is already too small. And winding 200 turns on this torroid will
    almost cost me a whole day. Is there a better way to get this done?
  9. Guest
    John,
    Any commercial products, i can buy quickly?
  10. Something like that. So to get that same effect at 1kHz, you will
    have to increase the inductance by at least a factor of 10, so the
    turns will have to increase by at least the square root of 10 or 38
    turns, minimum. Lets say 40. Then you need about 10 times that many
    turns on the secondary, center tapped. Of you stack two of these
    cores and cut the turns in half, etc.
    Use a larger core. Perhaps a LFB360230-300, $1.35 from Digikey.
    I suspect there might be something you could use, but you would
    probably be better off asking the makers than me.
  11. Tim Auton
    Tim Auton Guest
    10^0.5 != 38
    10^0.5 = 3.16
    Tim
  12. Now, multiply that factor times the 12 turns he has tested.
  13. Tim Auton
    Tim Auton Guest
    Sorry about that. We'll now return you to our usual programming.
    Tim
  14. Shouldn't take an hour. The trick is to wind all the wire you need
    and a bit extra over a soda straw, end to end. Notch the ends with
    scissors to help the wire stay on. Then you have a neat and thin
    object to pass through the core (instead of pulling a long lose piece
    of wire), with minimum fuss and tangle.
    After you have something that works, you can take the design to a
    custom magnetics house for a quote on automated production.
  15. Guest
    Thanks John,
    I see the part # LFB360230-300, why not get the one which has the
    higher Net impedance at 1 MHz, say LFB43064-000? That will ensure i
    have high enough reactance with fewest number of turns (to make my life
    easy).
  16. Guest
    Thanks John,
    easy).
    http://dkc3.digikey.com/PDF/T062/1057.pdf
  17. I picked one with a large cross sectional area, but also a large
    window area, in case you needed space for lots of turns, especially if
    you go with Kynar or Teflon insulated wire, yo lower the inter winding
    capacitance. For all they cost, you might as well get an assortment.
    You might also consider placing a pair of the tall, narrow form factor
    beads side by side, and winding through both, cutting the number of
    turns in half.
  18. Guest
    Works like a charm. I just finished winding and testing.
    Thanks a lot John, the core from the digikey was sufficient for the
    job.
    regards,
  19. Congratulations!
