Curbie said:
Say someone has 48V battery (bank) and inverter and their primary
charge is some alternative energy source (you pick it), what are the
pros and cons of backup charging between properly matched:
1) AC household voltage generator
2) I.C.E. with an automotive DC alternator?
Ulysses does something like this and I've reading through BobG's posts
on OtherPower along the same lines, my overall question is why?
1) Aren't most inverters designed for AC household voltage
generator?
I wouldn't say "most", but there are some that have built-in chargers.
2) If you go with AC household voltage generator, doesn't this
provide additional temporary backup against an inverter failure?
Yes. That's assuming you are concerned about inverter failure. I have
OutBack inverters and it's just not something that I think about. I suppose
it could happen, but I have two inverters and can run my whole house from
one so I have a backup. I also have a cheap MSW that I could use to run my
refrigerator if all else failed. And I have a propane refrigerator if I
can't get any electricity.
3) Is the I.C.E. with an automotive DC alternator just so much
more efficient for battery charging that it justifies the costs and
hassles?
Yes. I figured the losses using the chargers in my OB inverters at about
560 watts for each inverter/charger. With my Delco alternator the losses
are only about 200 watts plus some elusive losses due to friction etc via
the belt-drive. With a PMA that 200 watts could be reduced to a fairly
insignificant amount. I don't find it to be much of a hassle. I have my
alternator/charger calibrated so I simply set the engine speed for the
ultimate desired voltage. Plus I have the option of running it at a faster
speed and turning it down once the target voltage is achieved. If I choose
to go automatic with the alternator/charger I could connect it to my OB
charge controller, but then I'd lose more watts.
I don't know maybe I just missing the "Big Picture", could explain
this to me?
If someone is only using a generator occasionally then the efficiency losses
might not be so noticeable. But I generate ALL of my electricity burning
gasoline.
Another factor that is very important to me is the way the OB
inverter/chargers work: they have built-in transfer switches that
automatically switch over to generator power whenever the generator is
connected and running. This results in numerous problems such as nothing
works right and clocks run slow etc. With no significant loads present my
OB inverter, when connected to a generator, will not run my well pump or
microwave oven. The same generator, when connected directly, will easily
run either. I don't know why exactly but there are some huge losses going
on plus some other factors that I can't quite grasp. Not only that but the
inverters are very hard on generators. I have destroyed one generator twice
(got it repaired the first time) and had to replace the wiring harness on
another because it was overloaded and melted, even though I never knowingly
exceeded the capabilities of the generators. Plus the OB system varies the
charging current depending upon the loads present on the inverters. This
results in times when the generator is running with no load, not something
that I like to do. All-in-all if someone was to charge their batteries when
nothing was running from the inverters it may work satisfactorily but it's
just too much trouble for me. But, if the loads are running from the
inverters and the charging is done seperately by an alternator then none of
these problems exist. Everything works fine and there are no concerns about
surges or overloads etc, as long as you stay within the limitations of the
inverters. The load on the alternator is constant regardless of the loads
on the inverters. The output from the OB inverters is nothing to complain
about. Everything runs great and clocks keep accurate time and there are
simply no issues about running anything from them. As long as you don't
connect a generator to them.
OutBack's solution, supposedly, is to use a generator that has twice the
output of the combined total of the inverters. That means I would need a
15,000 watt generator. That also means I would have to run all of my major
loads (microwave cooking, washing machine, air compressor, etc) at the end
of the charging cycle otherwise I would have a huge generator running to
supply only a few hundred watts. To me this is much more of a hassle than
adjusting the engine speed on my alternator charger once-in-a-while. Plus I
don't even know for sure that it would work.
