Q
Qwerty
This is the first time I really started to mess around with one of these, but I have a display that is not
working correctly and have some questions as to how this is 'suppose' to work.
I am measuring 4.15v on all lines for the display, even on the pin that the segment is 'clear'.
What kind of signal is used to activate the segment as it does not seem to be DC controlled.
The driver is ok, I swapped in another display and it work fine. Is it possible that the display is not good (no physical damage, however),
or maybe there is something just 'goofy' with the display? Is it possible that the connections inside the
display have been servered on the non-working segments?
Not sure if back lit LCD's work the same as standard one (have no experience with either), but I kind of
assumed that you applied a DC voltage to each segment to activate it (like a LED), but this does not
seem to be the case in this situation.
I hope that is clear...
