B&K Precision frequency counter 1803
Discussion in 'Electronic Equipment' started by zeitguy, Apr 11, 2006.
  1. zeitguy
    zeitguy Guest
    This is an older model with no wall wart. Does anyone know the voltage
    and polarity of the miniplug power supply? How much damage could I do
    starting with 5 v dc tip positive? I have $40 in the unit, so I am not
    eager to fry it. Thanks for any help.
  2. Robert Baer
    Robert Baer Guest
    Sometimes using a DMM in the diode position will give the polarity
    ingo; other times a multimeter in 1K range will be needed for the
    polarity info.
    Another way is to take the case off and do xome circuit chasing; at
    times that bay also give a clue as to the probable input voltage.
    Ane then again, some meters have the voltage on a case label.
  3. zeitguy
    zeitguy Guest
    Thanks for the ideas. I took the case off and found an 6- AA cell
    battery holder inside, and the red lead from the battery holder and the
    lead from the tip of the power socket were soldered together, so it
    should be a 9 volt tip positive wall wart. In the meantime, I am using
    batteries, and it works great.
  4. zeitguy
    zeitguy Guest
    Thanks.
    I opened the case and found a 6 cell AA battery holder inside with the
    red lead and the socket tip lead soldered together, so it should be a 9
    volt tip positive wall wart, I suppose. I wish all my other little
    mysteries were so easy to solve.
