http://www.nitronex.com/solutions/NPT35050%20RF%20Power%20Transistor%20V1.3.pdf John
120 volts. 90 watts. 25 amps. 8 mhos. 200 C. All I need to know now are the capacitances. I want to use it in a wideband amp, 1-250 MHz maybe. It's input matched for 3.5 GHz, so I figure the matching will be invisible at 250 MHz, practically DC. At 2.5 Ghz it should be partially matched, but probably tunable. The drain is unmatched, fine with me. As soon as I blow one up, I'll open the can and see what's inside. John
How can its maximum operating junction temperature be greater than its maximum storage temperature? Bob
Those things really leak a lot- several watts could be lost to leakage in the 'off' condition. Might make a nice audiophile class-A amplifier. Best regards, Spehro Pefhany
Actually, that RF centric device would be quite expensive to incorporate into an audio amp, regardless of whether it would work or not. There a far far cheaper devices that are as good as they need to be for such a design.
Seems kind of open-ended. Surely if these guys can hear a staggering difference between cheap and expensive AC line sockets, response well into the hundreds of MHz may not be overkill. Best regards, Spehro Pefhany
The frequency isn't high enough. I need to make a crystal controlled 3.XXXXXX*10^14Hz signal. I'd take a lower power though.
The rep dropped off an eval board here, with a gadget on it. He claims we can get parts, but these exotic semiconductors do always seem to be six months off. They've added a "P" in the front of the part number, on the pdf datasheet, and he claims that means "production." We'll see. When/if we can get them, they will be a pretty radical change to the way people design wideband RF power amps. John
Like the old germanium transistor amps with just a cap into the base... self biasing! But a few watts of leakage won't be lethal for a 200 watt class AB push-pull amp, probably less than the normal quiescent power. John
