avrdude unable to program my ATmega328p microcontroller
Discussion in 'Microcontrollers, Programming and IoT' started by yamadanao, Jun 27, 2017.
  1. yamadanao
    yamadanao
    Jun 21, 2017
    I am going to be brief here. So I got my Atmega328p microcontroller from Arduino Uno(I pulled it out of the board). And then I bought my USBASP programmer chip to program my MCU. I properly installed its x64 drivers. Then I made my program to turn an LED on. It got compiled successfully and generated the hex file nicely.
    Here is the atmega328p datasheet
    BUT! when I try to program my MCU it gives an error like this:-
    ERROR LOG:-
    avrdude -p atmega328p -P usb -c usbasp -U flash:w:LEDON.hex
    avrdude: error: programm enable: target doesn't answer. 1
    avrdude: initialization failed, rc=-1
    Double check connections and try again, or use -F to override
    this check.
    avrdude done. Thank you.
    make.exe: *** [program] Error 1
    Then I try to program it using the -F parameter to know the problem more deeply, and I get this error:-
    avrdude: AVR device initialized and ready to accept instructions
    avrdude: Device signature = 0x000000
    avrdude: Yikes! Invalid device signature.
    avrdude: Expected signature for ATMEGA328P is 1E 95 0F
    avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
    To disable this feature, specify the -D option.
    I have tried everything, but nothing is working. I am using WinAVR on Windows 10 x64 OS. I can put the code if you guys want. Also I have double checked my MOSI, MISO, SCK, RST, Vcc and GND connections. They are perfectly fine.
