Av-28t25eks shut down after 10 seconds.
Discussion in 'Electronic Repair' started by Tim, Jun 28, 2006.
  1. Tim
    Tim Guest
    My JVC av28t25ek shuts down after 10 seconds. If I then turn the system
    off and on a few times it eventually stays on. Could someone point me in
    the right direction to repair this?? also where can i download the
    service manual.
    Any help would be great.
  2. Inty XP
    Inty XP Guest
    Chassis?
    B.T.W. change electrolytic caps in power supply primary and secondary ;)
  3. Cliff Top
    Cliff Top Guest
    Hi Tim,
    Send me your email and I'll send you the pdf manual.
    It's not a common problem, but what is happening sounds like the protection
    circuit tripping- may be a high voltage cap leaking or the Loptx arcing...or
    even an intermittent short in the tube !! .Its not old enough to have
    electrolytics at fault really.
    Andrew
