Categories
Platforms
Content
That would be the simplest implementation, but also the least intelligent in the sense that it will be a simple on/off with the tool that you tap into.Infact I see there are 230vac pneumatic solenoids available too.
Well, I see no way around this - you have a separate extractor for the treated wood, presumably you are swapping the main trunk connection between DC's. That means that all the drops stay the same, just the extractor is moved. That shouldn't take very long, well... then again, that all depends on how the system is plumbed.Hi. The times I alternate between treated and non treated timber are within weeks. Its not very often I use treated timber but its definitely a hassle having to change over machines.
LOL, good for you! It took me 2.5 years I would suggest a trial run with one gate at a time including your time delay before committing too many resources. That way you can tweak your prototype as you inevitably find improvements as the design progresses.Hmmm. Im going to do it! Just need to design my gate now for the pneumatic cylinder and cut it out on my cnc router. Yes having two extractors is a bit of a bonus.
Mr Chopnhack. Excellent advice. I just have to laugh when I realise how uncomplicated it has become. I read a post previously about using an arduino board which was an idea I played with. Purchasing one of those ended up in my building cnc equipment ha.
Now I want to automate everything......everything lol
Fair enough, but the link I looked at seemed to be some dodgy Chinese knockoff. I ordered a power supply like that one time and did not feel comfortable using it. They typically use cap. reactance to step down the voltage.provided the voltage and amperage meets the requirements of the solenoid yes?
There is nothing special about a power supply just because its for LED strips? 24vdc 1A is 24vdc 1A and thats that huh?
I make a point of not using AC solenoids, but much prefer the DC variety, I have see too many coil burn outs with AC especially if the armature spool fails to completely move over for some reason, also some have manually poked the armature over when the other side of a double coil type ending up with a blown board or a burnt coil.Infact I see there are 230vac pneumatic solenoids available too.
