automatic voltage regulator
Discussion in 'Electronic Design' started by [email protected], Mar 21, 2009.
  1. Guest
    i am currently doing project on Generator voltage control system.
    Could you send me circuit diagram for automatic voltage regulator that
    will give output voltage of 220V/50hz AC.
  2. Rich Webb
    Rich Webb Guest
    Sure!
    .---------------. Motor
    Command .---. | | .---.
    ------|Sum|------| Voltage |-----o----| M |-
    + '-o-' | | | '---'
    '-------------|Filter|---------'
    (created by AACircuit v1.28.6 beta 04/19/05 www.tech-chat.de)
  3. gearhead
    gearhead Guest
    You have a lot to learn, and not just about electronics. Like how to
    communicate.
    Care to give it another try?
    We're here to help.
  4. Not bad... ;)
    How about this:
    | | output
    Input o---------o MAGIC o-----------o
    Regards,
    Bob Monsen
  5. MooseFET
    MooseFET Guest
    He may need the isolated version:
    | | | | output
    | SOME | | MORE |
    Input o---------o MAGIC | | MAGIC o-----------o
    o---------o | | o-----------o
    If you take the knob off a variac, you can fit it with a pulley. A
    small gear motor can then turn the variac up and down. A meter-relay
    and a power relay can then control the power to the motor.
  6. whit3rd
    whit3rd Guest
    Generator? You're using a DC generator instead of an
    alternator? If it isn't a permanent magnet type, you'd
    just trim the output voltage by modulating the field coil current.
    To make it AC, there's lots of designs out there: look into
    into "variable frequency controls" that drive AC motors,
    for examples, or "power inverter" like provide AC in
    automobiles if your needs are low-power.
  7. gearhead
    gearhead Guest
    I am so BUSTED!
