Automatic Timed Polarity Switch and Shutoff
Discussion in 'General Electronics Discussion' started by jkompa, Mar 24, 2015.
  1. jkompa
    jkompa
    Mar 24, 2015
    First off thank you to anyone who is able to point me in the right direction. I am a mechanical guy and have confused myself trying to dig into circuit development.
    I am looking to keep the circuit as simple as possible. I will be powering system using a wall adapter for 110V AC however I have found wall adapters to convert this to 6V DC for me which I will use in order to simplify my circuit unless someone lets me know a reason not to. The 6V DC is what is specified for the two components I am trying to run, a Micro Stepper Motor and a UV Light.
    My system needs are as follows:
    - External Contact Switch
    - Used to connect the system (like a button to turn on)
    - this contact will be separated and reapplied manually to start cycle again when need be
    - System needs to run for 60 seconds and then turn off automatically
    - Micro Stepper Motor (specs 6V DC and 200mA (assuming this is start-up amps) down to 20mA (assuming this is continuous running amps)
    - Run oscillating while system is on as stated by the external contact switch above (60 seconds)
    - approximately 6 seconds forward followed by 6 seconds reverse
    - exact time isn't necessary but looking to have approximately 5 full cycles for the 60 seconds run time
    - UV Light (specs indicate 6V DC and 6mA)
    - Run continuously while system is is on as started by the external contact switch above (60 seconds)
    I believe I am going to need a 555 timer, possibly 2. One to control the total time till shutoff and one to control the time to polarity switch on the motor which I also believe would require an H-bridge to switch the polarity. All of the samples I have seen show additional resistors, etc. which I am uncertain what are for and seem to be over complicating the circuit, so that probably just shows how clueless I am. Also I am thinking that polarity switch for the motor may negatively affect the light so does that mean I need another switch for polarity at the light?
    Comments to point me in the right direction or a sample circuit diagram would be greatly appreciated.
    Thanks again.
  2. jkompa
    jkompa
    Mar 24, 2015
    Update to request, this will use just a regular DC motor not a stepper motor so just a 2 pin connection.
