Autohelm ST50 Speed not working, temperature -10 centigrades
M
Matti Raustia
Last summer it worked fine, now it shows only 0.00 kts. Other symptom is
that water temperature is -10 centigrades which is quite low... Any ideas
where to start looking for problem?
matti
M
Matt Colie
Matti,
Look at the connections on the back of the instrument first.
This instrument is has individual push in connections. If they are
poorly crimped or not clean, you will get nothing.
If that does not fix everything, look for splices in the 4-wire/shield
cable.
Sensor failures are relatively rare and seldom complete.
There is a good troubleshoot giude in the manual. If you do not have the
manual, it is available online at Raymarine.
Matt Colie
Yachtman's Technical Support
www.yachtek.com
M
Me
matti
Looks to me like your sensors are not connected. Look for a bad
cable....
Me
M
Matti Raustia
Thanks for suggestions. I'll check the cable first.
By the way, how is the paddle wheel sensor fastened in the through-hull
housing? I couldn't find this out from the manual and as my boat is in the
water, I dont want to do enything that might sink my boat...
matti
Jack Erbes
Most of them are round, have O-rings for sealing, and are pushed
straight down into a matching cylindrical hole. It will probably have a
notch or keyway to set the fore and aft alignment when all the way down
and is held in place by a cross pin that goes through the cylinder walls
and the top of the sensor. Or you may find a threaded collar that holds
the sensor in.
It should have come with a matching plug and you may find that stored
near or laying in the bilges by the through hull. Press a wadded up rag
or sponge over the hole as the sensor comes out, then put the plug in.
Some water will get in, depending on the depth of the fitting it can be
a fair stream. Plan on getting wet.
Airmar makes some through sensor through hulls that have a self closing
flapper valve that closes the hole as the sensor is pulled out. Those
do not give a 100 percent seal and you definitely want to put the plug
in place. Don't count on the self closing seal to keep the boat from
sinking!
A coating of a non-petroleum based O-ring lube on the outside of the
sensor will make fitting and removal easier.
Jack
