autoanswer telephone line
Discussion in 'Electronic Design' started by merco, Jul 12, 2006.
  1. merco
    merco Guest
    hi
    how is it possibile to wait for some rings and then activate the line
    to capture DTMF signals ?
    thank you
  2. OBones
    OBones Guest
    Yes.
  3. merco
    merco Guest
    well, i see...
    but i asked "how" ?
    OBones ha scritto:
  4. OBones
    OBones Guest
    I know, hence why I canceled the message, I missed the "how" part.
    Detecting rings is done with a RC network across the line, like on this
    schematic with R7/C3 (bottom right)
    http://obones.com/2Lignes1Tel/Schema.png
    On this one, you get an optocoupler in the path to interface with low
    level voltage (12V) logic.
    To activate the line, I think it's enough to put a resistor across it
    but can't remember the exact value. And detecting DTMF tones can be done
    with an MT8870 like on this schematic:
    http://obones.com/2Lignes1Tel/ToneCommand2#/Schema.png
    Hope this helps.
  5. merco
    merco Guest
    thanks, the problem i have is how to pick up the line...
    maybe a 600 ohm resistor ?
  6. John Fields
    John Fields Guest
    Yes, that will work.
    The second problem is that you're top posting. Please bottom post.
  7. You need several circuits.
    a. Ring detect circuit
    b. Something to count the rings before answer
    c. something to loop line and draw loop current from line/telephone exchange
    d. something to couple the audio after looping
    e. something to decode the dtmf
    f. something to hangup.
    JG
  8. Nico Coesel
    Nico Coesel Guest
    By using a ring detector, a DTMF receiver and a microcontroller.
  9. You mean an "infinity bug"?
    Michael
  10. Rich Grise
    Rich Grise Guest
    Hack an ordinary answering machine?
    Good Luck!
    Rich
  11. jasen
    jasen Guest
    a ring detector, monostable, counter, relay, line transfromer,
    DTMF decoder...
    or use a modem. many V90 modems will decode DTMF if you ask them nicely.
    Bye.
    Jasen
