auto scan fm radio problem
Discussion in 'Radio and Wireless' started by SAADELDIN, Oct 29, 2018.
  1. SAADELDIN
    SAADELDIN
    5
    Oct 29, 2018
    I have china-made auto-scan FM radio
    It was able to receive frequencies from 88MHz up to 103.3 MHz
    but not able to detect 98.2
  2. (*steve*)
    25,271
    2,718
    Can you manually tune it to 98.2MHz?
    Does it skip this frequency when scanning, or not recognize it as a station while scanning?
    How strong is this station compared to the weakest ones the scanner can find?
  3. H2814D
    H2814D
    75
    9
    Nov 4, 2017
    I had this problem with an old AC Delco FM receiver. Although I was also only having a problem with one or two stations, the antenna was the problem. Try a different antenna before messing with anything else inside. Also, if that doesn't work and you are going to open it up, check the antenna connections inside the case.
  4. SAADELDIN
    SAADELDIN
    5
    Oct 29, 2018
    HI SIR
    WE CAN T MANUALLY TUNE AT 98.2MHZ.
    IT SKIP THIS FREQUANCY WHEN SCANNING.
    WE HAVE MANY PCBA FOR THIS MODEL SOME PIECES DETECT FREQUENCY VERY GOOD AT SAME PLACE AND SAME ANTENEA,OTHER SKIP IT,AND WE HAVE SOME OLD SAME PCBA THAT WAS DETECT THIS FREQUENCY BEFORE AND NOW SKIP IT TOO.
    FOR THIS I THINK THERE S NO ANTENEA OR FREQUENCY PROBLEM
  5. (*steve*)
    25,271
    2,718
    OK THAT SOUNDS FINE. BUT CAN WE STOP SHOUTING?
  6. SAADELDIN
    SAADELDIN
    5
    Oct 29, 2018
    WE CAN T STOP SCANNING.5807 USING FOR FM WITH 24C02 AND MICROCONTROLLER.IS THE PROBLEM AT ANY OF THESE ICS?
  7. (*steve*)
    25,271
    2,718
    CAN WE STOP SHOUTING? IT MAKES MY EYES BLEED.
  8. SAADELDIN
    SAADELDIN
    5
    Oct 29, 2018
    (CAN WE STOP SHOUTING? IT MAKES MY EYES BLEED)
    I CAN T UNDERSTAND WHAT YOU MEAN
  9. davenn
    davenn Moderator
    13,438
    1,807
    turn off your caps lock
    typing in capitals means you are shouting
  10. davenn
    davenn Moderator
    13,438
    1,807
    and you still haven't given us the make and model of your radio
    have you looked online for a service manual or schematic ?
  11. SAADELDIN
    SAADELDIN
    5
    Oct 29, 2018
    its chinese pcba have 3 ics fm ic 5807 ,2402 and microcontroller i will send photo to you
    davenn likes this.
  12. Audioguru
    Audioguru
    2,694
    610
    Sep 24, 2016
    It might be a copy of the scanning FM "radio" I bought for $1.00 at the Dollar Store. It uses a Chinese copy of a Philips TDA7088 FM radio IC that does not work well. The radio came with earphones and a battery so the actual radio was free.
