D
David Chapman
As part of a larger system, I need to design and build an audio VCO
which will produce tones ranging from around 50Hz to 4KHz or so when the
applied DC input voltage changes from 0.5volts to 2.5volts.
This will be used simply as a tuning aid for visually impaired users
so the actual voltage/frequency relationship, and waveform produced, is
not at all critical. Supply voltage of the VCO can be in the range 3.3v
- 5v DC.
I'm considering using the CMOS 4046 PLL IC, but wonder if anyone in
this NG has any better suggestions to offer. FWIW, price is not the most
important consideration.
Any suggestions will be much appreciated.
TIA - Dave
- 5v DC.
TIA - Dave
