I am working on building an audio switch for my car that will allow me to hook my XM input and my iPhone (both 3.5mm) and switch between them on a single 3.5 mm output. I have seen plans and understand how to make one with a 3PDT switch.
I have found several inexpensive 3PDT toggle switches, however I would prefer to use a rocker switch so it looks cleaner. I can't find one for less than $15-$20, and since the point of this project is to avoid paying $30 for a prebuilt switch, I don't want to go that route.
If I understand how a 3.5mm plug works, there is a left and right channel and a ground.
The diagram I saw switched all three between the two, hence needing a 3 pole switch.
My question is, could I share the ground between the 3 at all times, and simply use a DBDT switch to swith the L&R Channels? Would this create a ground loop?
Also, is there an inexpensive 3PDT Rocker switch that I just can't find??
Lastly, how hard/expensive would it be to make the switch load sensing, hence automatic?
Thanks for any help!
