T
Tam/WB2TT
Ian Stirling said:Treble.
There is no real reason why you should lose bass, though it may decay
under
10Hz.
Irrelevant.
It's transmitted in a 75Khz bandwidth, about 32Khz above and below the
nominal frequency, and would have exactly the same information content
if it was centered on 88,108, or even 1Mhz.
Actually, it gets worse than that. In that 75 KHz channel, you have 15 KHz
of LEFT+RIGHT, another 15 KHz of LEFT-RIGHT (or is it RIGHT-LEFT), plus
MUSAC, or whatever. The LEFT-RIGHT channel is transmitted as a double
sideband suppressed carrier AM signal; so, it actually takes up 30 KHz. I
don't know this for a fact, but I suspect that if an FM station is
transmitting digital music, it is in the slot formerly used for MUSAC.
To transmit a 75 KHz bandwidth of signal, the FM transmitter actually uses
about 200 KHz of spectrum. That is just the way FM works. Defined by Bessel
Functions.
The 88 to 108 is immaterial, as has been pointed out. In the FM receiver,
the first thing that happens is that whatever station the radio is tuned to
gets converted to a narrow slot at 10.7 MHz. You can't make the slot wider,
or you would get interference from the adjacent channel.
Tam
