D
dspdspo
how do i distinguish between a recorded signal and a real time
signal?i.e. on what basis?
dspdspo said:how do i distinguish between a recorded signal and a real time
Frank said:Follow the cable. If it comes from the recorder, it is
carrying the recorded signal. If it goes to the microphone,
it is the real time signal.
Paul said:Let's assume that the recording wasn't made on a reel-to-reel, all-tube
recorder with gold plated chassis, oxygen free PTFE insulated cables,
all electrolytic caps replaced by polyester cotton, and mounted on
vibration-proof gimbals.
The problem then becomes easy- any hi-fi buff will INSTANTLY be able to
distinguish.
butUse Nyquist Sampling Theorem:
The signal that was digitally recorded will be band-limited in its
analogue reversion, whereas the signal that is real-time will not be
"as band-limited". For example, assuming that the digital signal was
sampled at 44.1kHz, you could take FT of that signal and check to see
how much power is beyond 22.05 kHz (rougly speaking). If there is "a
lot" of power, the signal could not have been digitally processed,
whereas if there is essentially none, then it probably
was....unless....the original source of the signal is Barry White, in
which case you will not see any power above 880 Hz, whether sampled or
real-time.
Note that you have to know the sampling frequency to make this work.
-Le Chaud Lapin-
That'll work. ;-)
ballstoall said:pls explain... i didn't get what you said about "a lot of power" beyond
22.05kHz...?
i mean, shouldn't there be a difference in the frequencies of recorded
and real time?
