Audio level with potentiometer
Discussion in 'Audio' started by rahulb, Apr 13, 2018.
Thread Status:
Not open for further replies.
  1. rahulb
    rahulb
    45
    Mar 14, 2018
    sorry for my foolish question, I am a newbie.
    I want to know at what resistance we get maximum audio level?
    I mean If we use 10K potentiometer in a amplifier circuit, will we get maximum audio level at 0 resistance or 10K resistance.
    thanks in advance.
  2. BobK
    7,673
    1,684
    Could be either way. Depends on the circuit.
  3. duke37
    duke37
    5,297
    739
    Jan 9, 2011
    The volume control is normally connected to earth at one end and to the signal at the other end. A slider picks up the voltage for output. If the slider is near earth, the voltage is minimal. If the slider is at the 'top' then the signal will be maxixmum. Volume controls usually have a logarithmic track so that the movement gives a gentle variation at low levels and varies rapidly at high levels.
  4. adir figueiredo
    adir figueiredo
    3
    Apr 18, 2015
    lembrando que o potenciometro logaritmico tem a letra A
    google translation: remembering that the logarithmic potentiometer has the letter A
  5. (*steve*)
    25,292
    2,731
    @rahulb you need to learn that replying in your threads is an available option.
    I'm going to close this thread. You should stick to your original thread where there is enough information to actually answer the question.
    see here.
Thread Status:
