D
David Chapman
Low-cost commercially available audio pre-amplifiers are usually very
vulnerable to interference from adjacent cellular phones switching, in
the UK, at around 217Hz.
When designing an audio amplifier with high immunity to such
interference, I can see the obvious value of adding suitable RF
filtering (ferrite chokes and shunt capacitors with low-Z in the UHF
band) to the input circuitry but wonder if a pre-amplifier using
differential inputs (FET or Bipolar ?) rather than single-ended would be
better. Transformer coupling of source to the amplifier input is another
possibility, of course.
To meet a current requirement that I have to meet, amplifier noise
should not be too much of a problem since the input signal levels are in
the region of 20-50mV pk-pk, with a bandwidth from around 300Hz to 5KHz,
and the output level required is around 2 volts pk.pk. into a nominal
600 ohm load.
Does anyone with practical experience of dealing with this problem
have any comments that they'd care to make about how to minimise such
interference?
TIA - Dave
David C.Chapman - Chartered Engineer. FIEE. ([email protected])
600 ohm load.
interference?
TIA - Dave
