ATX power supply to bench supply conversion
Discussion in 'Electronic Repair' started by Kingcosmos, Apr 2, 2007.
  1. Kingcosmos
    Kingcosmos Guest
    Hello,
    Not sure if this is the best group for this. I found several articles
    on the process of using an ATX power supply and convert it to a bench
    supply. The problem I am having is that the wire color codes and pin
    outs are not standard ATX. I looked several places, including this
    website, to see if I could find out what the pin outs would be.
    It is a LiteOn 140W PSU with +/-5V, +/-12V, +18V, and +5V standby
    (underside of the PSU). I actually had to open it to see what wires
    were what voltage. The board actually has them listed as:
    6 Red: +5V
    5 Black: Ground
    1 White: +18V
    1 Yellow: -12V
    1 Purple: -5V
    1 Grey: PG, I am guessing 'Power Good'
    1 Orange: +12V
    2 Brown: P/C and F/C (not sure what these are supposed to be)
    The pinouts from 1 to 20 are:
    Red
    Black
    Red
    Black
    Grey
    Red
    Orange
    Yellow
    BLANK
    White
    Brown
    Black
    Black
    Black
    Purple
    Red
    Red
    Red
    Brown
    BLANK
    Any ideas? I am out of them. Thanks in advance.
  2. Lionel
    Lionel Guest
    Um. What's your actual question? Your colour coding looks correct at a
    glance, so you know which voltages should be on which wires. As you
    guessed, PG = "power good", so all you need to do it short the grey
    wire to a black wire (you can use a 1K resistor if you're feeling
    paranoid), & the it'll power up just fine. I have a couple of PC PSUs
    set up the same way on my own bench.
  3. Kingcosmos
    Kingcosmos Guest
    I guess it is ok; however, every single site I go to does not show
    this pin out or color coding for an ATX power supply. Real quick,
    Blue is -12V on every site that I have seen...among others.
    The question I really wanted to ask concerned the brown wires. Not
    sure what they are supposed to be. The board says P/C and F/C. If
    shorting the grey wire to ground is all I need to do, I will set that
    up and just measure them with a Fluke.
  4. Franc Zabkar
    Franc Zabkar Guest
    +18V is not a standard ATX voltage. Furthermore, the LiteOn has no
    +3.3V rail. Could this supply be for an industrial PC ???
    Power/Control ??? Fan/Control ???
    - Franc Zabkar
  5. Meat Plow
    Meat Plow Guest
    A 140 watt supply in an industrial PC? :)
    Maybe it's out of an Apple?
    #1 Offishul Ruiner of Usenet, March 2007
    #1 Usenet Asshole, March 2007
    #1 Bartlo Pset, March 13-24 2007
    #10 Most hated Usenetizen of all time
    Pierre Salinger Memorial Hook, Line & Sinker, June 2004
    COOSN-266-06-25794
  6. Lionel
    Lionel Guest
    That's what I'd do.
  7. Kingcosmos
    Kingcosmos Guest
    Success!
    The grey wire appears to be power good so that should be an output. I
    connected the only +5V coming up (which I think is the standby
    voltage) to the brown wire P/C (I agree-- power control), and the rest
    of the rails came up.
    Everything looks good. Still not sure about what the supply actually
    is.
  8. Franc Zabkar
    Franc Zabkar Guest
    In a regular ATX PSU, the PS_ON pin is shorted to ground to turn on
    the supply.
    Could the 1-wire 18V rail be for an LCD panel or touch screen ???
    Point of Sale system ???
    - Franc Zabkar
  9. JW
    JW Guest
    Sure! We ship industrial nema-4 systems with even less power. 50-80 watt
    power supplies and mobile processors.
