S
Sam Goldwasser
Would NOT having memory or any peripherals plugged in prevent
an ATX power supply from turning on? I'm not referring to an
SMPS loading issue but an actual logic lockout. I can force the
power supply on by grounding the PWR-ON (green) wire but the
tower case power button has no effect. It is receiving some
voltage and does ground the power-on pin on the mainboard (which
is of course NOT directly connected to PWR-ON of the power
supply) when depressed but has absolutely no effect.
It's from a Compaq mini-tower.
The story I got was that this started when a new video card
was plugged in, possibly askew. However, that story is
somewhat jumbled so I don't have a lot of confidence in it.
Is the computer likely to boot and run properly "hot wired"
or is there some reset/initialization that really requires
the proper power on sequence?
--- sam | Sci.Electronics.Repair FAQ Home Page: http://www.repairfaq.org/
| Mirror Site Info: http://www.repairfaq.org/REPAIR/F_mirror.html
Important: The email address in this message header may no longer work. To
contact me, please use the Feedback Form at repairfaq.org. Thanks.
