Jim Baber wrote:
John, there are also "wholehouse fans" for you to consider as well.
If you are not familiar with them, they are installed in the ceiling
below the attic near the center of the house, and pull warm air from the
living areas and push it into the hot attic thereby forcing that hotter
attic air out of the attic.
These fans are very effective if the inside air is warmer than the
outside air, but they do require that you open windows or provide
another source of outside air in the living areas.
John said:
I am wondering if anyone has personal experience with attic fans?
My wholehouse fan reduces the need for air conditioning by about 6 hours
a day in 100+ heat and 10 hours in 90 - 99 heat, and eliminates A/C
below 90 when I am trying to maintain a 79 degree temp. in the summer in
Fresno CA. It works this well, because of our usually low humidity.
The nights usually are below 80 after 9:30 - 10:30 even on most 100+ days.
i.e. pumping hot air out of the roof space/attic during summer?
It requires that you also have very good attic venting, I have 3
turbines and several regular regular vents. I have found that
occasionally on very hot days if I run the wholehouse fan for a short
time occasionally, it helps by forcing the super hot air from the attic,
but that means I am pulling hot outside air in from the window (I just
open one window near the fan), and that does not upset the general
inside temperatures, but does cool the attic just like an attic fan would.
Would be interested to know if it is worthwhile.
Without a doubt. I am very sensitive to the temperature, and my health
is such that I require A/C in the summers here. (this year beginning
Jun 15 for the 90 days ending yesterday we averaged 99.5 degrees F. at
5:00 PM) I was reasonably comfortable keeping the temperature in my
house below 80, and yet I kept my actual a/c usage to a minimum.
One thing I might mention, I cool the house as much as I can in the
mornings before it gets hot outside using the wholehouse fan and even
the a/c, BUT, then after noon or if the temperature outside goes above
79, I close all windows and shut everything off until after 6 PM.
I am on what PG&E calls Time Of Use metering, for the power I use. That
means for the summer weekdays between noon and 6 PM, I have to pay 3
times much for "Peak" power than what I pay for all the other "Off Peak"
power we use. PG&E's obscene rates are why I have invested in solar PV
to the extent that I have.
