I'd like to use a solar panel to run two AC 3.4amp attic exhaust fans. What
sort of components would I need to do this? I know I'd need the panel and an
inverter, but I'm not sure if I'd need anything else. I'd also appreciate
advice on exactly what models of equipment would suit my needs.
It seems to me that using an AC motor with an inverter is wasting a
good percentage of the power. I would use the 12VDc off the panels
with a DC motor such as the fan motor from a front wheel drive car, or
maybe one even more powerful than that. Also, if the panel isn't
getting full sunlight, then the DC motor might run at half speed,
where the inverter might not run the AC motor at all.
Oh, one other thing. It seems that a convection system might be the
way to go with this attic ventilation. And also there are those wind
turbines that run off convection.
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it:
http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
