Ok, so I received an early 70's HH Scott R 36 S solid-state receiver and all it does is hum. The hum is independent of the volume control and input selection. From what I've read on this so far, the problem is most likely bad filter can-caps.
So I opened it up and took a look at the big capacitors. There one big 70v/4700uf and two 35v 2200uf. I took them out of the circuit and started testing. Capacitance meter says they're values are good. Ohm meter doesn't indicate shorts or opens. I even hooked a 9v to them one at a time, unhooked and watched the voltage drop with a multimeter. So far the caps are testing good, but they're 40 years old and the thing just hummmmmss so I'm not convinced.
I would just replace them and see if that works but I'm on a budget and it seems like I should be able to verify good or bad caps between a capacitance and multimeter.
Would testing the caps to see if they hold a voltage over a period of time be a good indicator of anything? If I charge them up with a 9v, should I be able to let them sit for a few hours and then see it discharge with the multimeter?
I've scoured the web and I'm lost when it comes to testing caps. One person will say get a cap meter, the next an esr meter, and the next says you need both, then another says they're all worthless. So I'm a little confused!!!
If it's not the caps causing this hum, what else could it be?
Thanks in advance for your input!
