ATF2500C atmel datasheet
Discussion in 'Datasheets, Manuals and Component Identification' started by xyz, Jan 30, 2014.
  1. xyz
    xyz
    Jan 30, 2014
    I am looking at this datasheet:
    http://www.atmel.com/Images/doc0777.pdf
    This datasheet of ATF2500C CPLD. Is it true, that with this chip it is not possible to add numbers? For example in altera EPM7000 series there is sum functionality.
  2. (*steve*)
    25,500
    2,840
    I can't see any reason why you couldn't implement the logic required to sum numbers.
  3. xyz
    xyz
    Jan 30, 2014
    You are completely right. I am in error, since while look for FPGA I sow "full adder" term. Actually it is not add 2 numbers (integers), just add 2 bits (numbers 0 or 1), which is about 1 or 2 "xor" and one "and" gates.
