Atari ST video (VGA/TV/Atari) output board
Discussion in 'Electronic Design' started by SixteenThirtytwo, Mar 3, 2007.
  1. In the process of recasing and modifying my Atari Mega STe I've come
    to the video output section which I'm building a new output board for.
    Since I don't have much design experience I need some help in getting
    this right.
    Here's my schematic, drawn in Eagle:
    http://img204.imageshack.us/img204/9301/vgalogicpo4.png
    First some information about how the video modes work on an unmodified
    Atari ST.
    There are two modes. Each mode only works with its own dedicated Atari
    monitor:
    - High resolution monochrome mode: 35.70 KHz horizontal, 71.2 Hz
    vertical
    - Low/mid resolution colour: 15.75 KHz horizontal, 50-60 Hz vertical
    The computer defaults to colour mode if a colour monitor or no monitor
    at all is attached to the computer.
    If a monochrome monitor is attached however then computer "senses"
    this because the monitor's 13 pin male DIN connector has its pin 4
    (mono detect) connected to pin 13 (GND), which sets the computer to
    mono mode once such a monitor is attached.
    My new video output board is meant to take the existing signal and add
    on it so that I can:
    - use standard PC (VGA/SVGA) monitors (mono mode)
    - use a standard TV (colour mode)
    - use Atari colour and mono monitors as before
    I've designed the circuit to work like this:
    - a manual switch allows me to choose between colour/mono modes
    - in order to prevent damage to monitors/TVs because they receive sync
    signals outside of their range (especially older monitors) I'm routing
    only the appropriate sync signals belonging to its dedicated
    connector.
    So far so good, but I need some help with what I've so far figured out
    in theory, but I don't know which components I need to get this done
    or how to connect them together. Here's my idea (which I've drawn into
    the schematic as block-diagrams):
    A (4 pole?) "electronic switch" (U1) of some sort (is this what's
    called a "multiplexer" IC?) works as
    a multiple 3 way switch. Those 3 are:
    A: when an Atari mono monitor (SM-124 etc.) is present
    B: when no Atari monitor is present
    C: when an Atari colour monitor (SC-1224 etc.) is present
    In positions A and C the manual colour/mono switch (S1) is bypassed
    so changing the modes will have no effect. In other words, whenever an
    Atari monitor is used it will work just like with an unmodified Atari
    ST.
    In position B however the manual switch (S1) will be in control.
    Control of the electronic switch (U1) for positions A and C is
    dependant on some logic (AND/OR gate ICs?), and to determine this a
    micro-switch is to be placed inside the 13 pin DIN (female) connector.
    This switch will sense whenever an Atari monitor's (male) connector is
    inserted. So now we have a system which "knows" when an Atari monitor
    (mono or colour) is present or not.
    Next we need to determine if that Atari monitor is a colour or mono
    monitor.
    A mono monitor as we know has pin 4 (mono detect) connected to GND
    (pin 13) internally, which the Atari colour monitor doesn't.
    I assume this will generate a logic high/low (correct me if I'm wrong)
    and can further be used to control the U1 logic switch circuit and set
    it in position A or C.
    Positions A and C will as mentioned above shut off the manual switch,
    and also give sync signals only to those connectors (TV or VGA) which
    correspond to the mode which the computer is currently in.
    Finally, there's the LEDs.
    If the pin 4/GND issue above works I would think that yet another
    logic circuit can be used, only this time for controlling two LEDs.
    One LED indication "colour mode" and another LED for indicating "mono
    mode".
    How do I design this with my existing circuit?
    If necessary I can upload my Eagle schematic file.
    Finally, there's the matter of optimizing the video signals. I've been
    told that my schematic has several shortcomings where I should
    terminate the signals properly, that my R-G-B level trimpot (RV1, RV2
    and RV3) solution isn't a good one and so on. All that stuff is
    unknown territory for me, so any suggestions are welcome.
  2. OK, since I'm getting no response here, are there better suited groups/
    forums for discussing video related electronic circuit designs?
  3. Joel Kolstad
    Joel Kolstad Guest
    comp.sys.atari.st.tech?
    From taking a brief look at the schematic, it doesn't really look like there's
    much "design" there. It might be easiest to just build the thing a section at
    a time on a solderless breadboard and see what happens. The video signals may
    be a little degraded, but the idea is to verify the signal levels and logic,
    right?
