AT89s52 Port 0 always HIGH
Discussion in 'Microcontrollers, Programming and IoT' started by chetan_129, Jan 26, 2020.
  1. chetan_129
    chetan_129
    Jan 26, 2020
    I have made an AT89S52 board on zero pcb ( the schematic is shown in the attachment)and burned the below code in controller.
    The problem is PORT 0 is always HIGH(0XFF). all the other ports are showing expected result(0XAA). I have tried keeping Pin PSEN both HIGH and LOW but nothing worked.
    I have also checked resister pack connections and the resistance between port pins and VCC. it is also correct.
    PORT 2 has the same kind of res pack and same connections and its working fine, so what could be wrong with PORT 0?
    Any kind of help is appreciated.
    Thanks!!!
    Code:
    org 0
    mov a,#0xaa
    mov P0,a
    mov P1,a
    mov P2,a
    mov P3,a
    sjmp $
  2. Harald Kapp
    10,025
    2,138
    Probably unrelated to your problem, but: PSEN is an output and should not be tied to VCC.
  3. chetan_129
    chetan_129
    Jan 26, 2020
    Is there any possibility that only PORT 0 is damaged and not the remaining ports ??? if yes, how can i check it.
  4. Harald Kapp
    10,025
    2,138
    Try another chip.
