AT Power Supply question: "Power Good" signal
  • Thread starter Marcel Gonzalez
  • Start date
M
Marcel Gonzalez
Hello.
Can I use this signal to drive an LED for visual indication ?
Thanks.
Marcel
C
cpemma
Marcel said:
Hello.
Is there a need? If it's "good" the other 5v or 12v lines will work (to
which a led is easy to attach), if not the psu will shut down.
W
Wayne
Marcel Gonzalez said:
Hello.
Thanks.
Marcel
This is usually the output of some comparator like LM393.. Should be able
to sink 10ma no problem.
I beleive this signal is low if power is good.
