Ask a Silly Question ...
Discussion in 'Electronic Basics' started by Rich Grise, Aug 27, 2003.
  1. Of course one must then be very careful to get the "source" and "destination"
    the right way around. My (business) partner once "ghosted" a blank
    drive onto our main server hard disk :) :)
  2. I bet you gave him "The business!" after that. ;-)
  3. Rich Grise
    Rich Grise Guest
    OK, I'm responding to myself - sosueme. ;-)
    I've been out of the loop for awhile, kinda in transit. I got the serial
    thingie going, (a half-null modem, kinda - I did the 9-pin equivalent
    of 4&6-20, and looped back the other HS line). Transferred a couple
    megabytes in about an hour. Most of which time was spent dicking
    around with windoze software.
    So I put the old 4 GB drive in the new computer - all I had to do
    was change the jumper from master to slave, and I had to use the
    ribbon cable from the old comp, since the new comp is so barebones
    that the IDE1 cable didn't even have a connector for the slave.
    Took about 2 minutes to physically move the disk (I'm a hacker,
    after all - one screw, two connectors, done!), and another 2
    minutes to drag and drop the whole drive's contents
    into its own dir. on the new drive. Of course, when I booted,
    W2K found all four partitions, so I've got C:, D:, E:, F:, G:,
    H:, I:, and J: drives. "Windows has found new hardware ..."
    I gotta admit, somebody at M$ was apparently awake one day; it's
    turning out to be quite nifty. Please don't gouge my eyes out. ;-)
    Since then, I've done the same with my latest client's computer -
    The guy said, "Before you do anything to this computer, BE SURE
    YOU SAVE EVERYTHING!" The client's comp. is a Compaq Presario.
    A bunch of USB ports, but I contemplated tying up both comp's
    for however long, so I just pulled the drive and dragged and
    dropped it onto the new drive. I'm at the client's comp. now,
    and it turns out that we're not going to midify it much - I
    think I have them almost talked into using Linux for the firewall
    and network server, but that's kind of down the line.
    But I do want to thank everybody for participating in what
    seems to be a lively discussion and like that. :)
    The whole operation was a great success, and I have determined
    that using COM ports for a network is a really stupid idea. ;-)
    With computers these days, you don't even need a freaking router!
    They come with like 6 USB ports by default!
    Yeah, I think this is going to be a fun assignment, except for
    the fact that my two primary cow-orkers are a Luddite who, if
    he wasn't doing it 50 years ago it doesn't exist, and a male
    psycho bitch from hell, but what the heck - it pays the bills,
    and the fringe bennies are kinda cool - like, they're letting
    me live in my house-car (Winnebago) in their parking lot, for
    zero rent.
    Again, and I hope it's not the beer talking, thanks everybody for
    responding to the thread, and all that yadda blah. %-}
    Cheers!
    Rich
  4. John Fortier
    John Fortier Guest
    Rich,
    My office PC went west a couple of weeks ago. Crashed processor and no hope
    of recovery. I tool the disk out, changed it to slave and pushed into my
    home PC. Absolutely no problem.
    It's also allowed me to exchange data between the drives like never before,
    so, it's a valuable exercise, even if it was an emergency move.
    I'd recommend disk moving any time with modern PCs, It's literally plug and
    play.
    Regards
    John Fortier
  5. Dennis Clark
    Dennis Clark Guest
    I just went through this - Save yourself some SERIOUS sweat.
    Fire up Winzip and zip up directories.
    bring up Hyperterm on both computers
    connect them at the highest rate you can (115K usually)
    connect the serial ports using a null modem connector
    send the zip files from one to the other computer.
    This works well, reliably and fast enough for me anyway.
    You'll still have to install all the apps on the new computer to get all
    of the registry settings right, but the data can be dumped through using
    the zmodem file transfer via hyperterm.
    good luck and have fun,
    DLC
    : Hi. I just bought a new computer, and was thinking of ways to get all
    : my stuff
    : from the old computer to the new one. I thought, "serial link," which
    : would
    : be fun anyway. So, since the local RS is in disarray during
    : remodeling, I went
    : to the local Home Club and got some 4-conductor, jacketed, shielded
    : wire.So, OK, cool - I've got that stranded bare drain wire, which is
    : frame ground,
    : obviously, and a red, green, black, and white wire. So black or white
    : would
    : be signal ground, and red/green RxD and TxD. So, what's the thing to
    : do with
    : the excess wire that makes the most sense? There _are_ four_
    : handshake lines,
    : if I want 1/4-duplex handshaking. If I did that, are there any ideas
    : as to
    : which particular wire (RTS -> CTS, DTR -> DSR, one way or the other)
    : it
    : would do any good to connect? Or should I just tie it off.
    : Thanks!
    : Rich
    : If you want to email me, elide 'ard'.
