R
Robert C Monsen
John Fields said:Thank you John,
As I said previously, I have a lot of difficulty with ascii
schematics. I
copied the complete post and will have to go thru it slowly to try
and
understand it. Is there a site I can visit for a tutorial on ascii
schematics? I am seeing more and more of them lately. I just don't
understand what some of the symbols mean and how they are connected.
It's fairly easy, but different folks use slightly different
conventions sometimes, so it gets confusing. Basically, here's what
I
do:
Vertical wire: |
Horizontal wire: ---------------
Wires crossing but not connected: ---|--- or -------
Wires connected: ---+-+---
2-leaded components:
Basically, describe what it is with an alpha designation in
brackets,
put some wires on it, and connect it to something.
Horizontal R1
Resistor --[100K]-- or --[100K]-- or --[R1]-- or --[R]--
Vertical R1| | | |
Resistor [100K] or [100K] or [R1] or [R]
Horizontal C1
Capacitor --[100µF]-- or --[100µF]-- or --[C1]-- or --[C]--
Show polarity where needed, like for electrolytic capacitors:
C1 + |+
--[100µF]-- or [100µF]
and diodes:
A = Anode
K = Cathode = >
K |A
--[1N4000>]-- OR --[1N4000]-- OR [1N4000]
For transistors and FETs, label the terminals and put in aything
else
you need to :
Q1 C D
---B NPN ---G
2N4401 E 2N7000 S
For opamps and comparators:
For larger blocks, identify the part, label the connections and
enclose them in a box. I like to use +'s for the corners, other
folks
use dots or single quotes or commas. Add pin numbers if you like,
or
whatever will make your meaning clear
----|TR- |
----|TH OUT|----
----|D |
555
For switches:
____
---O O--- or ---> |
O
Then just hook it all up:
+12 +12 +12
[10K] [10K] 555 [1M]
| <--+-[0.1µF]-+----|TR- OUT|---|---->OUT
O | DIS|---+
GND | TH|---+
[1µF]
GND
That's a 555 timer which puts out a pulse about 1 second long each
time you press the switch.
Also, there's a free ASCII schematic drawing program out there which
a
lot of people use to post stuff to the non-binary newsgroups. I
forget what its name is (Andy's something-or-other, I think) and the
link to it, but I'm sure somebody will post that info if you ask for
it or if they read this.
Andy´s ASCII-Circuit v1.25.250804 www.tech-chat.de
