AS3008
Discussion in 'Sensors and Actuators' started by Phillc1, Oct 5, 2021.
  1. Phillc1
    Phillc1
    4
    Oct 5, 2021
    Im researching the electrical compliance of my 7 year old Metricon home after a bad day yesterday chasing faults.
    Can you point me in the right direction?
    Re AS3008
    It transpires the builder has used 3 x 40 amp rcd circuit breakers in the meter box.
    The 40 amp breaker tripping 2-3 minutes after being reset had 18 dbl GPOs and 12 lights on it including 4 X
    HPM 10 Amp AQUA Double Switched Weatherproof
    Which as it happens were full of salty moisture and dirt with corroded screws.
    These proved to be the problem.
    Is this legal?
  2. davenn
    davenn Moderator
    13,883
    1,964
    So, replace them ....
    anything with corrosion is going to cause a problem ... how did they become exposed to salty moisture ?
  3. Phillc1
    Phillc1
    4
    Oct 5, 2021
    Thanks Davenn
    New info as from today.
    It took 7 years for them to fail.
    However it transpires they were not installed properley.
    Internal base plate screws designed to have pips covering the screw heads( fixed into green wall plugs) however all hpm aqua ppts have no pips covering screw heads.???
    99% waterproof is not water proof as all, as it turns out.
Similar Threads
Loading...
