Arium RP256 eprom emulator
Discussion in 'Electronic Equipment' started by delo, Sep 29, 2004.
  1. delo
    delo Guest
    I have a little box named Arium Rp256
    In the upper side of the box is a small idc male connector called IN and a
    db
    female connector named OUT.
    In the lower side are six connectors for the emulated roms.
    I begin to rev-eng the pcb to see the connections.
    What I like to do is put it to work connected to a PC parallel port,
    does anyone have an electric diagram, timing, source or binary code
    to use it?
    Also someone know what type of equipent use it?
    I guess a philips dev-sys.
    bye
    Tia
    John
