Are these components worth salvaging?
Discussion in 'General Electronics Discussion' started by bigone5500, Oct 27, 2015.
  1. bigone5500
    bigone5500
    712
    121
    Apr 9, 2014
    I have these components to salvage but if they have no real practical purpose then I will not worry about them.
    Linear LTC1286, DIP-8, Micropower Sampling 12-Bit A/D Converter
    http://cds.linear.com/docs/en/datasheet/128698fs.pdf
    TI LT1013CP, DIP-8, Dual Precision Operational Amplifier
    http://www.ti.com/lit/ds/symlink/lt1013am.pdf
    Microchip 24C01C, DIP-8, 1K 5.0V I2C Serial EEPROM
    http://ww1.microchip.com/downloads/en/DeviceDoc/21201K.pdf
    Microchip PIC16C63A-04/SP
    http://ww1.microchip.com/downloads/en/DeviceDoc/30605c.pdf
    TI SN74HC373N, Octal Transparent D-Type Latches with 3-State Output
    http://www.ti.com/lit/ds/symlink/sn54hc373.pdf
    TI ULN2004AN, High voltage, high current darlington transistor arrays
    http://www.ti.com/lit/ds/slrs027n/slrs027n.pdf
    Deal or no deal????
  2. Colin Mitchell
    Colin Mitchell
    1,417
    313
    Aug 31, 2014
    Just keep them "as is" until you need them.
    And you might get some surface mount resistors and capacitors from the board too.
    It all depends on how much experimenting you do.
    A 2 cent part will cost $5.00 if you have to buy it.
    Memory_Leak likes this.
  3. Memory_Leak
    Memory_Leak
    11
    Oct 27, 2015
    I can think of a lot of uses for high power transistor arrays. Keep those for sure.
  4. bigone5500
    bigone5500
    712
    121
    Apr 9, 2014
    I'm going to need more storage bins...
