Arduino sketch fails to restart after power cycle
Discussion in 'Microcontrollers, Programming and IoT' started by Fred Lewis, Feb 23, 2017.
  1. Fred Lewis
    Fred Lewis
    Feb 23, 2017
    When the sketch#1 is uploaded, it WILL NOT restart after a power cycle and must be reloaded.
    When the Blink program from the built in examples is uploaded it WILL restart after a power cycle.
    When the ReadAnalogueVoltage from the built in examples is uploaded it WILL NOT restart after a power cycle.
    Sketch #1
    -drives a sensor which communicates with Micro#1 via I2C on pins 2 and 3
    -drives Xbee#1 which communicates with Micro#1 on pins 5 and MOSI
    Xbee#1 is paired with Xbee#2 on another breadboard on which also sits Micro #2 and an LCD for output. Xbee#2 uses pins 3 and MOSI to communicate with Micro#2.
    Sketch#2 restarts properly in Micro#2.
    When Micro#1 and Micro#2 are swapped and sketch#1 loaded in Micro#2 the situation is the same, ie sketch#1 WILL NOT restart.
    Saving this annoying situation, the whole thing works well. Valid data is acquired by the sensor, sent properly from one Xbee to the other and is accurately displayed on the LCD.
    It cannot be (at least I don't think it can be)
    -a fault on either bootloader
    -a fault on either Micro
    -unlikely to be RFI or other EMI interfering with the bootloader restarting the sketch as the Blink program does restart
    I must find out what is going on before I start shooting in the dark.
    HERE IS THE CODE FOR SKETCH#1
    Code:
    /****SKETCH_DAremoteDriver
    READS BME280, CALCULATES DA, SENDS DATA TO COORD. XBEE****/
    #include <SoftwareSerial.h>
    #include <Wire.h>
    #include <math.h>
    #include <cactus_io_BME280_I2C.h>
    const float c0 = 6.1078;           //constants for satVapourPress
    const float c1 = 7.5;
    const float c2 = 237.3;
    const float RdryAir = 286.9;       // gas constant for dry air J/kg K
    const float RwaterVapour = 461.5;  // gas constant for water vapour J/kg K
    const float dA1 = 44.3308;         // constants for densityAlt
    const float dA2 = 42.2665;
    const float dA3 = 0.234969;
    const float kmToFt = 3280.0;        // converts km to feet
    const float cToK = 273.15;          // converts *C to *K
    const float mbToPasc = 100;         // converts millibars to pascals
    const int Rx = 16; //the micro can't use pin 2 for Rx
    const int Tx = 5;
    float satVapPress;        // saturation vapour pressure mb
    float parPressWatVap;     // partial pressure of water vapour mb
    float parPressDryAir;     // partial pressure of dry air mb
    float airDensity;         // air density kg/m3
    float densityAlt;         // density altitude in feet
    float tempVar1;           // temporary variables for long equations
    float tempVar2;
    float temperature;        // sensor temperature value
    float rh;                 // sensor relative humidity value
    float pressure;           // sensor pressure value
    int tempDA;
    /****SO THAT END POINT XBEE 2 BYTE DATA CAN BE SENT AND REASSEMBLED AT COORDINATOR XBEE****/
    int LSBtempDA;
    int MSBtempDA;
    int LSBpressure;
    int MSBpressure;
    int divisor = 256;
    int rhInt;
    int temperatureInt;
    int pressureInt;
    SoftwareSerial xbee(Rx, Tx);
    BME280_I2C bme;           // Create BME280 object I2C using address 0x77
    void setup()
        //delay(5000);
        //pinMode(2, INPUT_PULLUP);
        Serial.begin(9600);
        while (!Serial);   //because it takes a while to make the serial connection which is why println would not display
        xbee.begin(9600);
        Serial.println("Bosch BME280 Pressure - Humidity - Temp Sensor | cactus.io");
        if (!bme.begin())
           Serial.println("Could not find a valid BME280 sensor, check wiring!");
           while (1);
           //pins A4 (SCK) and A5 (SDA), used for I2C on the Uno are pins 2 (SDA) and 3 (SCL) on the micro
        bme.setTempCal(-0.5);        // Temp was very close so subtract 0 degree
        Serial.println("Pressure\tHumdity\t\tTemp\t\tsatVapPress\tparPressWatVap\tparPressDryAir\tairDensity\tdensityAlt");
    void loop()
        bme.readSensor();
        temperature = bme.getTemperature_C();
        pressure = bme.getPressure_MB();
        rh = bme.getHumidity();
        satVapPress = c0 * pow(10, (c1 * temperature) / (c2 + temperature));   //calculate water vapour saturation pressure
        parPressWatVap = satVapPress  * rh / 100;                              //calculate water vapour partial pressure
        parPressDryAir = pressure - parPressWatVap;                            //calculate dry air partial pressure
        tempVar1 = parPressDryAir * mbToPasc / (RdryAir * (temperature + cToK));          //first term of airDensity
        tempVar2 =  parPressWatVap * mbToPasc / (RwaterVapour * (temperature + cToK));    //second term of airDensity
        airDensity = tempVar1 + tempVar2;                                                 //calculate air density
        int densityAlt = round((dA1 - dA2 * pow(airDensity, dA3)) * kmToFt);   //calculate density altitude in feet
        Serial.print(pressure); Serial.print(" mb\t");
        Serial.print(rh); Serial.print(" %\t\t");
        Serial.print(temperature); Serial.print(" *C\t");
        Serial.print(satVapPress);  Serial.print(" mb\t");
        Serial.print(parPressWatVap);  Serial.print(" mb\t\t");
        Serial.print(parPressDryAir);  Serial.print(" mb\t");
        Serial.print(airDensity);  Serial.print(" kg/m3\t");
        Serial.print(densityAlt);  Serial.println(" ft");
        tempDA = abs(densityAlt);
        /****Each call sends 3 bytes to coordinator xbee packing its read buffer with 12 bytes.***/
        DisassembleSendData(densityAlt);
        DisassembleSendData(temperature);
        DisassembleSendData(pressure);
        DisassembleSendData(rh);
        delay(4000);    // Add a 4 second delay
    void DisassembleSendData (float dataToDisassemble)
      int tempVar;
      int LSB;
      int MSB;
      int divisor = 256;
      /***Disassembles sensor data into 3 bytes***/
      tempVar = dataToDisassemble;
      LSB = tempVar % divisor;
      MSB = (tempVar - LSB) / divisor;
      /***Sends 2 bytes to coordinator xbee read buffer***/
      xbee.write(LSB);
      xbee.write(MSB);
    HERE IS THE CODE FOR SKETCH #2
    Code:
    /****This drives the Coordinator Xbee.  It receives data from the Remote Xbee, conditions it
    and presents it for output.****/
    #include <LiquidCrystal.h>
    SoftwareSerial xbee(16, 3); //Rx TX
    LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
    int temperature;
    int rh;
    int pressure;
    char c;
    int densAlt;
    int LSB;
    int MSB;
    int fractionalPart;
    int LSBpressure;
    int MSBpressure;
    int divisor = 256;
    int counter = 0;
    char units;
    void setup()
      Serial.begin(9600);
      xbee.begin(9600);
      // set up the LCD's number of columns and rows:
      lcd.begin(16, 2);
      Serial.println("hi fred");
      Serial.print("in setup");
      //lcd.print("hello, world!xxx");
    void loop()
      // set the cursor to column 0, line 1
      // (note: line 1 is the second row, since counting begins with 0):
      lcd.setCursor(0, 0);
      if (xbee.available() >= 8)
        //Density altitude data
        //fractionalPart = xbee.read();
        LSB = xbee.read();
        MSB = xbee.read();
        units = 'f';
        //AssemblePrintData(fractionalPart, LSB, MSB, units);
        AssemblePrintData(LSB, MSB, units);
        //Temperature data
        LSB = xbee.read();
        MSB = xbee.read();
        units = 'C';
        lcd.setCursor(0, 1);
        //Pressure data
        LSB = xbee.read();
        MSB = xbee.read();
        units = 'm';
        //Relative humidity data
        LSB = xbee.read();
        MSB = xbee.read();
        units = '%';
      //Serial.println("out of if");
    void AssemblePrintData(int LSB, int MSB, char units) //(int xbee.read(), int xbee.read(), int xbee.read()) ???
      lcd.print((MSB * divisor + LSB)); /*lcd.print("."); lcd.print(abs(fractionalPart));*/ lcd.print(units); lcd.print(" ");
      Serial.print((MSB * divisor + LSB));/* Serial.print("."); Serial.print(abs(fractionalPart));*/ Serial.println();
