Have written this:
// this constant won't change:
const int buttonPin = 2; // the pin that the pushbutton is attached to
const int ledPin = 13;
const int ledPin2 = 12;
const int ledPin3 = 7;
const int ledPin4 = 4;
; // the pin that the LED is attached to
// Variables will change:
int buttonPushCounter = 0; // counter for the number of button presses
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the button
int current; // Current state of the button
// (LOW is pressed b/c i'm using the pullup resistors)
long millis_held; // How long the button was held (milliseconds)
long secs_held; // How long the button was held (seconds)
long prev_secs_held; // How long the button was held in the previous check
byte previous = HIGH;
unsigned long firstTime; // how long since the button was first pressed
void setup() {
// initialize the button pin as a input:
pinMode(buttonPin, INPUT);
// initialize the LED as an output:
pinMode(ledPin, OUTPUT);
pinMode(ledPin2, OUTPUT);
pinMode(ledPin3, OUTPUT);
pinMode(ledPin4, OUTPUT);
// initialize serial communication:
Serial.begin(9600);
void loop() {
// read the pushbutton input pin:
buttonState = digitalRead(buttonPin);
// compare the buttonState to its previous state
if (buttonState != lastButtonState) {
// if the state has changed, increment the counter
if (buttonState == HIGH);
// if the current state is HIGH then the button
// wend from off to on:
buttonPushCounter++;
Serial.println("on");
Serial.print("number of button pushes: ");
Serial.println(buttonPushCounter);
} else
// if the current state is LOW then the button
// wend from on to off:
Serial.println("off");
// Delay a little bit to avoid bouncing
delay(50);
// turns on the LED every four button pushes by
// checking the modulo of the button push counter.
// the modulo function gives you the remainder of
// the division of two numbers:
if (buttonPushCounter >0) {
digitalWrite(ledPin, HIGH);
if (buttonPushCounter >1)
digitalWrite(ledPin2, HIGH);
if (buttonPushCounter >2)
digitalWrite(ledPin3, HIGH);
if (buttonPushCounter >3)
digitalWrite(ledPin4, HIGH);
delay(500);
digitalWrite(ledPin, LOW);
digitalWrite(ledPin2, LOW);
digitalWrite(ledPin3, LOW);
digitalWrite(ledPin4, LOW);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
if (buttonPushCounter == 4) (buttonPushCounter = 0);
// END OF CODE
I had it working this morning but I was modifying it and accidentally changed something, now it doesn't work..
I'm sure it's improper use of '{' or '}'..
I'd be very grateful for someone to de-bug this :S Also, I'm not sure how to add the debounce to this - whenever I try to do so I get errors..
Tom
