Arduino GPS Transmission
Discussion in 'Microcontrollers, Programming and IoT' started by _Nate_, Mar 11, 2018.
  1. _Nate_
    _Nate_
    99
    Jun 12, 2017
    Hello! I am attempting a new project and I need some guidance. This project involves live GPS tracking, transmitting from a device and receiving from another. So far my game plan is:
    Use some GPS positioning module on the transmitting arduino to communicate with my other arduino using HC-12 wireless modules. I then want to somehow be able to visualize this data on a map displayed on an lcd or something.
    My main questions are:
    Would this work?
    What is the best in general, and then the best but cheapest GPS module that can complete this task?
    How can I visualize the GPS on a map?
  2. _Nate_
    _Nate_
    99
    Jun 12, 2017
    #1 Priority is a small size FYI
  3. (*steve*)
    25,360
    2,755
    What do you want to display on the LCD? Is it the relative positions of the two devices?
    If so, you can do it the "right" way, which involves lots of math that would take forever on an Arduino, or you could take the far simpler approach of getting the difference between the latitude and longitude values and applying a correction factor for your latitude, and simply plot one point against the other.
    You will probably want to average the values over time as they are likely to jump about a bit.
  4. _Nate_
    _Nate_
    99
    Jun 12, 2017
    I would like to display a map with the point of the device I am tracking on the lcd, if possible just tying in with google maps and an esp8266.
    Thanks for your reply!
  5. (*steve*)
    25,360
    2,755
    That is both easier and harder :)
    I'm sure you can tell Google maps to return a given area, and to overlay something at a particular lat/long.
    The problem is that you note require internet connectivity, a tcp/ip stack, and the ability to handle the data stream in both directions.
    I would be looking for existing applications that interface a microcontroller with Google maps. If you can find one, work from that.
  6. _Nate_
    _Nate_
    99
    Jun 12, 2017
  7. (*steve*)
    25,360
    2,755
    Well, that project doesn't actually use Google maps from the microcontroller, so it's not a good starting point.
  8. davenn
    davenn Moderator
    13,553
    1,852
    ... either Google maps/Google earth using kml or kmz file and you are going to need an internet connection
    the only other way is to find out how they produce and store map files in a car GSP system and do it that way.
    And that way is probably "biting off much more than you can chew" ... ie ..... way out of your league
  9. _Nate_
    _Nate_
    99
    Jun 12, 2017
    Is there a way I can download a map or something with coordinates coded in? I can have the gps unit and the HC-12 to transmit that data to my home arduino where it is plotted on the map.
