Jeroen Humasol
- Nov 8, 2015
- 68
- Joined
- Nov 8, 2015
- Messages
- 68
Hi guys,
I know it's probably impossible, but electronics has amazed me before so i'm just going to ask. I would like to test the efficiency of a solar dryer for drying coffee beans. I already have a sensor for: temperature, humidity and solar intensity. However it would be great if i could measure the 'hot humid airflow' leaving the solar dryer. Solar dryers work by natural convection. So you have large openings at ground level (if you look closely at the picture below you can see that there's a small distance between the cover and the ground) where cold dry air enters. This cold air gets heated and rises because of natural convection. While doing this it carries the moisture of the beans with it. Once it reaches the ceiling it exits the solar dryer through a small opening close to the roof.
You probably already guessed that the flow speeds will be very low (i've no idea how low, but let's say 0.5 km/h or something). Do you guys know if there exists an affordable sensor that i can hook up to my arduino to measure this? Thanks!
