M
mkr5000
Let's see if I can explain this --
I'm doing a drawing for an aluminum chassis and I want a 90 degree
bend exactly on the edge of the material. (062 aluminum)
Now, the way it's supposed to be done is that you cut/punch a couple
of arcs on each side of the bend, right?
Here's my question:
What are the guidelines for sizing these arcs? For example, should
the arc radius be 3-4 times the size of the material thickness?
(more? less?)
Say, the "O" is actually an arc (half circle) and the bend is between
the 2 "O's"
--------------O----------------------O---------------
Here's my question:
(more? less?)
the 2 "O's"
