D
D from BC
I'm gluing a part to a heat sink with a non-conductive thermal
adhesive.
After cure, testing shows no conduction between the part and the heat
sink. Good..
Problem: After power up, a short occurs between the part and the
aluminum heat sink. After power down, the part is still shorted to the
heatsink!! Bizarre..
There is no testing mistake.
(200VDC exists between part and heat sink during normal operation.)
What's going on?
Is it possible that an small arc develops in the adhesive . The arc
vaporizes some aluminum. Then when the power is cut off the aluminum
vapor cools and develops a conductive bridge (a short).
Possible?
Or maybe the arc burns the adhesive and the burnt adhesive is
conductive..
Anybody encounter something like this?
The shorting effect doesn't happen when I increase the bond line.
However, I'm trying to keep my bond line to a minimum.
D from BC
adhesive.
sink. Good..
What's going on?
Possible?
conductive..
D from BC
