T
Tim Shoppa
We're all familiar with making analog amplifiers by using a
digital (e.g. 74C04, 74HCU04, CD4069, etc.) inverter and putting
feedback around it. Or you start with a "differential pair/inverter"
like the CD4007.
These amps are usually used in non-critical applications like
oscillators or limiters where they are happily run until they limit
near the supply rails, or where you know that signals will be small
enough to not hit the rails.
But say I wanted to use something like this in an application where
I wanted to use them over their fairly linear range (maybe 0.3Vdd to 0.7Vdd)
to preserve wave shape without going into limiting by applying AGC
to the amplifier. The input signal (kHz) only varies by a factor of 5
or so (0.1V P-P to 0.5V P-P) and what I want to do is make its amplitude
be constant despite changes in signal strength (which happen over a timescale
of seconds). I'm not too picky about the size of the output signal although
it'd be nice to have it be a volt or two P-P. Keeping THD under
10% would be great, I'm not picky about that either.
Now there aren't a lot of spare pins on an inverter to inject an AGC
voltage. Modulating Vdd probably tweaks the gain but doesn't do me a lot
of good because reducing Vdd also makes it more likely that the signal
will hit the limit, defeating the purpose.
If I use two transistors of a CD4007 for the amp, I've got a couple of
spare N and P channel transistors left to use. I can take one of the
spare transistors, make it part of the feedback loop, and vary the voltage
on the gate to change its transconductance.
Is this an "old trick" where someone can point me to existing designs?
I'll probably have to go to the bench and measure the individual MOS
transistor characteristics to get transconductance as a function of
gate voltage, because all the data sheets seem to treat the CD4007 as
a digital, not a linear device
Is there a better trick?
I was figuring on just using an external diode or two to develop the
AGC voltage and get an AC waveform out that was a couple diode drops
big. Is there some trick for turning the unused MOS transistors in the
CD4007 into diodes?
Tim.
like the CD4007.
CD4007 into diodes?
Tim.
