Apple 21" monitor model M1823
Discussion in 'Electronic Repair' started by Aslaner, Apr 17, 2004.
  1. Aslaner
    Aslaner Guest
    I have this monitor that has a problem as follows;
    The monitor power on with the high voltage but the power supply area (small
    board on the left handside as seen from the back) it sounds like a relay
    clicking at a high rate, I don't get a screen , I don't let it turned on for
    very long.
    I took it all apart and found an IC on the main board that had some cold
    joints which I have redone, but nothing else that I can see, no bad caps
    etc no shorted components
    Maybe someone has see this fault before?
