Apple 17' M6496 Monitor fault
Discussion in 'Electronic Components' started by IanV, Jan 7, 2004.
  1. IanV
    IanV Guest
    This monitor Powers up with no Anode voltage.
    On secondary side of T701 , CN P701 pin 4 has +5VDC . Pins 1,2,3.5-10
    are dead .Meter test on all component's in the general area seem to test ok
    .. Circuit on primary side of T701 functions fine. Disconnecting P701 or CRT
    PCB makes no change in status.
    HOT(Q707),FBT(T703),IC701,Q404,D405,714,404,C411 & R439 are good.
    Any help would be gratefully appreciated.
