Aperture (electronic iris) manufacturer?
Discussion in 'Electronic Components' started by Pete Gray, Apr 10, 2005.
  1. Pete Gray
    Pete Gray Guest
    Does anyone know where I could purchase a standalone aperture (electronic
    iris) mechanism ? - i.e. the type with a tiny servo attached.
    Thanks, -Pete.
  2. Dave
    Dave Guest
    I've not seen them with a variable iris, only an open/close shutter, but
    http://www.mellesgriot.com/default.asp
    or
    http://www.edmundoptics.com
    would be worth asking. Professional optics components tend to be expensive.
    You might find a cheap lens that has the right control for use on CCTV
    cameras, in which case I suspect taking the lens apart and removing the
    glass might be a cheap alternative.
    An ex-collegue of mine developed a variable shutter/iris as part of his
    PhD. For the application, there was no commerical alternative - money
    was no object, but he had some rather exacting requirements.
    His PhD thesis is online
    http://www.medphys.ucl.ac.uk/research/borl/homepages/florian/thesis/
