APC SmartUPS 1400 Battery Upgrade
Discussion in 'Electronic Repair' started by Michael Kennedy, Jun 23, 2005.
  1. I recently got a SmartUPS 1400 and it had 2 12v 18ah batteries in series.
    One had ruptured and the other still works but is not to full capicity. I
    replaced them with 2 12v lawnmower batteries to see how long it would run.
    It only has a runtime of 10 mins at 30% load.. ???!! I believe it is
    oveheating or is shutting down on a timer, because when you plug it back in
    it says the batteies are 95% charged. Has anybody ran into this before? It's
    not draining the batteries much at all..
    - Mike
  2. Found my answer at
    http://home.tekies.net/HowTo/UPS Upgrade.htm
    Here is the article off APC's Web site.
    Smart-UPS XL models are not designed with communication modules to the
    external
    battery packs. It is important to follow these instructions. The number of
    batteries effects the runtime calculations which a Smart-UPS performs when
    it
    is running on battery power.
    There are three ways program the Smart-UPS XL to recognize the appropriate
    number of external batteries.
    1. Using Hyperterminal or Terminal Program to change the number of
    external battery packs
    Hyperterminal:
    HyperTerminal is used for Windows 95, Windows 98, Windows NT 4.0, Windows
    2000, Windows XP, and Windows 2003
    To adjust the number of battery packs via a Hyperterminal session:
    1. First, EXIT out of the PowerChute plus Server. In the case of Windows NT,
    the UPS service must be stopped.
    2. From the Desktop, go to: Start |Programs | Accessories | HyperTerminal.
    Double-click on the HyperTerminal icon.
    3. You will next be asked to choose a name and select an icon. Give it any
    name and then click OK. If a message appears which reads "...must install a
    modem," disregard it and continue.
    4. The port settings are 2400 baud, 8 data bits, 1 stop bit, no parity, flow
    control is Xon/Xoff.
    5. Click on Advanced and ensure the box labeled FIFO buffer is NOT checked.
    6. Click OK twice.
    **Please note that if you have the scroll lock on, Hyper-Terminal may not
    communicate properly with an APC UPS or
    accessory.
    Once the terminal/hyperterminal window is open, follow these steps:
    a. Type "Shift-Y"which should produce an 'SM'
    b. Type ">" To see the number of external packs. (A new unit will display
    '000.')
    c. Type "+" Adds a battery pack
    d. Type ">" To see the change in number of external battery packs
    e. Type "-" Subtracts a battery pack
    f. Type ">" To see the change in number of external battery packs
  3. Mike Berger
    Mike Berger Guest
    Either you didn't give us most of the information or this isn't your
    answer. The standard SmartUPS 1400 uses 4 12 v 7 AH batteries in
    a series-parallel combination. I have not had any real success
    using higher capacity batteries in these -- they don't charge
    properly and seem to have a shorter lifetime.
    You didn't mention that you have an XL model and that does use
    the 12v 18 AH batteries, and has a different charger.
  4. Clint Sharp
    Clint Sharp Guest
    Ooh, lovely, hope you've got a good fire extinguisher or didn't follow
    those instructions too closely. Please make sure that you use a grommet
    in any holes drilled through the metalwork if you're going to run cables
    through them, it's asking for trouble especially with the high currents
    the UPS and batteries are capable of providing.
