P
Peabody
This is an APC Model BE550G UPS. It's just a few months old, but
has developed an intermittent problem that I'd like to fix if I
can. I know if I send it back to APC it will just happen to be
working then, and I will have accomplished nothing.
The problem is that sometimes when the UPS switches into backup
mode, no power gets to the plugged-in devices. It's apparent the
UPS thinks it's supplying backup power (4 beeps every 30 seconds,
just like the manual says), but it isn't. The battery shows as
fully charged, with 27 minutes of run time available. And when it
works, it works fine. So it's not the battery.
I first noticed this during powerup of the UPS. At first,
everything is on mains AC. Then it switches into backup mode as a
test for a few seconds, then reverts back to mains AC. What I
noticed was that my modem would turn on at first, but then turn
back off when the UPS went into test backup mode, then turn on
again at the end of the test period. Sometimes. Most days, but
not every day.
Then of course I tried a full test - unplugging the UPS from the
mains, and all the devices shut down instead of continuing to run
under backup power. But all of this is intermittent. Sometimes
when I do the test, it works fine.
I called support, and they had me reset the sensitivity of the UPS,
and of course it started working then. But I strongly suspect this
has nothing to do with sensitivity - after all, it's hard not to
notice the mains dropping out completely.
Logically, what this seems like to me is that everything is working
ok, but the relay which switches over to supplying backup power to
the devices has bad contacts that don't always make contact. I can
hear the relay click when it goes into backup, and again when it
reverts to mains, and I can hear that whether the backup power gets
through or not.
Well, I just wondered if anyone here has any experience with this
kind of thing, and might offer some advice on what to try. I have
already opened it up and made sure all the internal cable contacts
are good, even tightened a couple just to be sure, but that didn't
help.
Any advice would be appreciated.
not every day.
through or not.
help.
